I am trying to do my first movie (Moulin Rouge.mpg imported) with Spruce Up (full version), when I go to play on Clip properties the program either freezes or gives message about problem with GPI.DLL which is to do with Intervideo Win DVD, am not sure what to do! Have tried unistalling/reinstalling Spruce, no different. Dont have any other DVD player software on Pc (Power DVD etc). Thanks in advance for assistance............??![]()
I think the problem is the built-in player. I recommend you to use the simulation to check if the menus are correct, not for playback. Save as files(I dont remember the correct choice) and try opening the .vob file with other DVD player software(I think there's a freeware one around). Or if you are making a Mini-DVD you can try burning it(I made a good anime Mini-DVD with Spruce).
Thanks Saito, I did everything without using the Intervideo player, hoped for the best and was chuffed to find it all worked!! I made my first vid with chapters, hooray!
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 05:10 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33
