  1. is there a way to make the sound louder
    i was thinking of changing the bit rate to 320. Will that work?
  2. Can you provide more info - hardware, capture app, settings?
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. yea i'm using tmpeg and i was looking under the audio part of settings.
    i just want to be able to make the sound louder
  4. In TMPGenc, after you load your encoding template click the settings button. Select the Audio Tab. Then check the Audio Edit box & click on it's settings button. You can increase volume above 100% to get it louder..
    Good luck.
