I am about to start to convert some VHS tapes to a CD format that will work on a work mates DVD player, it’s a Sony 300 series which is locked to region 2. OK, the forums have given me the info I need to as to what the DVD player will play and how, my question is –
If the player is locked region wise and I do not want to use say two of three CD-R’s, when I get my DVD writer can I create “Burn” VCD’S, XVCD’S onto a DVD-R, or DVD+R and use the medium as a large capacity CD-R format?
This would get away from the multiple disc problem, and allow space saving on the living room shelf?
See this guide & if the method is what you want:
http://www.vcdhelp.com/vcddvdr.htmPanasonic DMR-ES45VS, keep those discs a burnin'
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 14:23 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 01:00 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
