Results 1 to 9 of 9
  1. I have an mpg :
    source.......: dvd retail
    format.......: ntsc svcd (480x480, 29.97fps)
    video: 2075kbit avg. 2450kbit max 3-Pass VBR
    audio: 224kbits 44.1khz
    I open virtualdub add subtitler filter and start frameserver
    Does anyone know why i have these freaking lines
    Playing the source mpg on my dvd shows none of the freaking lines.But i need to add subs but it looks shit then
  2. OPTION 1: Deinterlacing For TV/Film/Any Video Source:
    1. Use Smart Deinterlace filter (eliminates 80-90% of the interlaced lines).
    2. Use Blur filter (eliminates the rest of the lines).
    3. Use Sharpen filter (makes the picture clear again without bringing back the lines)
    4. Use subtitle filter (Vobsub?).
    5. Last use Smart Resize filter. (Always use precise bicubic)
    6. Frameserve
    7. Encode as Progressive video (looks great on TV, Computer, HDTV)
    OPTION 2: Deinterlacing Only For Film Video Source (best quality for film):
    0. Frameserve from VirtualDub
    1. Inverse Telecine in Tmpgenc
    2. Encode as Progessive video w/ 3:2 pulldown
    Since, your source is Austin Powers, a film, you should use OPTION 2 for optimal quality. OPTION 1 should work fine as well.
  3. none of the above works.
    I still have those shitty lines
    Weird stuff
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Could it be the order of filters? Using Option 1, it's important thet the subs are added next to last, before the resize filter.
    /Mats
  5. Now i tried Ice Age and i have the same lines, but only on the characters that r moving
  6. Hi.
    Sorry, but I am a little confused here!
    If the source is a DVD, then the video file is a MPG-2. I tought that you can not open a MPG-2 in VDub. So how are you going to add subtitles to a MPG-2 frameseving from VDub to SVCD in TMPGEnc?
    From the guide the only two ways to add subtitles to a DVD Rip is using Flask or DVDX. Am I correct?
    Thank you
    8)
    Rey
  7. First i use dvd2avi to extract the sound, which also creates a .d2v file
    Then i use ssa2srt to make the ssa
    Now i make a filename.avs with the script in it.
    LoadPlugin("f:\movies\DVD2SVCD\SimpleResize\Simple Resize.dll")
    LoadPlugin("f:\movies\DVD2SVCD\MPEG2Dec\mpeg2dec.d ll")
    mpeg2source("d:\movie\movie.d2v")
    Then in virtualdub you open the filename.avs which also opens the mpg file.
    And then i can add subs and start frameserver
  8. Ops!
    I was looking for a guide to do that, but never found it. Now, I know it can be done.
    I'm still not sure how you did it. Anyway, thank you again and sorry for disrupting your post.
    THX
    8)
    Rey
  9. Try this:
    When you use DVD2AVI , select video -> field Operation -> Forced Film.
    Save your D2v file.
    Check your results.
