  1. Hey
    I got 2 problems. :
    1. i tried to burn 2 different movie files in svcd anf vcd the frontpage is ok but when i play the movie on my dvd player the movie is upside down and mirror like. ??????? Why ?????
    2. when you got a moviefile that is to long to be on one cd, is there a program that can cut it in 2. ???
    I burn with Nero - and Neo
  2. To correct your first problem load the avi into v-dub and choose the "flip vertical" in filters I think and then just frameserve to the encoder of your choice, or if your using TMPG I think there is a checkbox for it under advanced. To edit, just use v-dub on the avi's or TMPG has an "mpeg tools" in the files tab. That works pretty good for me. You may have to de-mux and re-mux if your audio falls out of synch after the edit
