have they come out yeat? 7-8 gig double sided
Double sided yes, they are out there. Double layer, no and not likely to ever be.
Pioneer makes some but they are very expensive... I think a few of the ultra cheap manufactuers do also. -
Flame me if i'm wrong but i remember reading that dual layer disks are pressed on top of eachother and therefore will not be able to be burned by a conventional dvd writer. So not likely to be available ever unless writers are built for it.
You are correct about dual layer disk... he was asking about the double sided disk and they are out there, though I myself have not messed with them.
PrimeDisc makes 9.4Gb double-sideds, which you can currently get from www.shop4tech.com for $2.79 apiece.
I haven't used the double-sided ones, but I've used their single-sided discs with good results, so I have no reason to doubt that the double-sided ones would work just as well... -
Speaking of Primedisc just got my first batch in... so far the only movie I burned was 4.1gb but so far they are doing great. I still suggest getting a test batch before jumping into a huge ammout though as I've not tested them completely yet.
fester:
http://www.dvdplusrw.org/media/dvdplusrw_media.html#smac , double side dvd+rw...dont think there are any double sided dvd+r out yet.
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 14:13 -
How do I burn a DVD bigger than 4.7 GB?
By Rayroshi in forum Authoring (DVD)Replies: 12Last Post: 29th Nov 2011, 07:02 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
bigger DVD-RW's than 8.5gb??
By cedarhill in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2008, 14:46 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
