is there a tool out there that will tell me all the info about a mpg file?
looking for bitrate, aspect ratio, cbr or vbr, gop, and most important! interlaced or not.
i have some shows i ripped from my tivo and converted them to m2v and m2a file but when i import it into DVDit PE, create chapter points and then try to create a thumbnail DVD it pukes and says the file isn't supported. it will play the file fine though.
i think it is because it is interlaced and dvdit wants non-interlaced
maybe you try Bitrateviewer
get it here http://teco.emg.hu/bitratev/BV.EXE
Peter
Tool that gives more info about .mp4 than GSpot
By Wam7 in forum Newbie / General discussionsReplies: 15Last Post: 7th Nov 2019, 05:51 -
Blu-Ray angle Info tool
By Oktober in forum Blu-ray RippingReplies: 7Last Post: 22nd Jul 2011, 06:07 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
What is the name of this video/audio info tool?
By ZoNi011 in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2010, 04:53 -
Video info tool (cmd-line-way) wich one?
By squadjot in forum Video ConversionReplies: 2Last Post: 19th Sep 2008, 15:01
