  1. When I convert avi widescreen movies to mpeg, I then burn to Video Cd using Nero. When I play the vcd on my player, it seems like it stretches the video even though it looks good. IS there anything I can use to not make it stretch? I use TMPG to convert and Nero to burn. It sucks because all of the movies I get are widescreen. Any help? Thanks
  2. yes... When you use TMPG, go look in SETTINGS -> Advanced tab -> Source Aspect ratio -> 4:3 (depending on wut you want, select here, i use 625 PAL 704*576)
    now when you convert, you shouldn't have a 16:9 (or widescreen) MPEG
  3. Even when i do those options, the screen still looks strectched. The only way to get to the options is when Im in the project wizard. Any help?
  4. and that fixes the problem... well, i'll get u in the wizzard then
    (very simple)
    FILE->PROJECT WIZZARD
