Generally speaking what would be better? A capture card or a bridge. All would be in a reasonable price range, say $300 or less. Any good suggestions on what I should get? My sources would be cable TV not digital cable, and from a Sony Handycam. Both would be analog. the Handycam uses Hi8 8mm tapes. Both sources are NTSC. Any good suggestions on what I should get or not get? Hauppauge seems interesting, or would Dazzle bridges be good? Then again, Hauppauge has TV tuners too.
-TIA
Have a look at this card . It may suit your needs.
http://www.canopus.com/US/products/advc-50/pt_advc-50.asp#technical_specification
Using this card will offer the same advantages as the dazzle bridge (from what the spec sheet reveals)
You could go one step further and run the VCR through it for TV captures in a DV format of `3.7Mb/sec.
ARRRRR!
No bridge!
Use the canopus or Datavideo DAC-100.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 12:06 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
