Hi folks,
I have a set of DD trailers and similar .VOB files on my computer HD.
Is there a way to burn these into a CD so that my SHARP 740U DVD
player can play back with DD 5.1 digital out ?
I tried buring them as files on to a CD but the player wouldn't play it.
What do I need to do ?
thx
termy
If you had a DVD writer you could use this:
http://www.vcdhelp.com/forum/userguides/120021.php
If you only have a cd writer you may not have enough space.
It is still possible to author DVD structures and burn them on a cd but the limit is about 12 to 15 minutes of video.
To gain more space (time) you would have to convert them to mpeg at a lower bitrate and reauthor them to vob. Don't know if it would be worth the effort.
Unless you convert them to mpeg and burn as (x)(s)vcd there's aren't too many other options.There's not much to do but then I can't do much anyway. -
sometimes we all cant have what we really want...
i got those trailers also,eventually ill burn to dvd
if u really want to burn vobs buy a dvd writer
ur gonnna get one in the end anyway -
thanks gll99. I will buy a DVD writer later. But for now I tried to burn the
VOBs into a CD by authoring them in the DVD structure as explained in
the link. It worked !!
I had only a few trailers..so space wasn't an issue.
thx
termy -
I think you are in luck as your Sharp can handle MiniDVD.
That is the name when when your burn a CDR with DVD standard.
http://www.vcdhelp.com/dvdplayers.php?DVDname=740&DVDselect=&minidvd=1&Search=Search
So use this guide below on how to burn VOB trailers.
You will only fit around 15-20minutes on a CDR.
will .vob files alone play in a home dvd player?
By vincy in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2012, 05:04 -
How to play raw DV files?
By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2011, 07:00 -
How Do I Play Raw DV Stream Files on a TV?
By NY2LA in forum Software PlayingReplies: 97Last Post: 29th Jul 2011, 23:21 -
Do Any Blue Ray Players Play raw m2ts files?
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Nov 2010, 21:41 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 05:31
