  1. Hi
    i need know how activate suport for dual processor in CCE,
    my brother have an Athlon XP 2.0 and i have 2 x Athlon MP 2ghz, but the time of encode 75min of video is practicatly the same, in the tmpgen i have reduction of 40% less time 75min of avi in 250min in VBR 2 pass in HQ (very slow)
    i have CCE 2.5 and 2.62
    thanks
    RhC!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    its already built in ... check your taskmanager cpu graph
  3. it's true this function it's built in,
    why the encode is very slow Speed 0.831 - 1.10 ????
    i view more speed in P4 processor
    thanks
  4. Similar problems with my dual CPU setup were caused by the single threaded source file read/decode routines being unable to feed enough data to CCE. What's the source AVI compressed with, assuming you're not frameserving?
  5. for example en dvd2svcd the CCE speed encoder is 25% less an 0.900, i used frameserver in there.
    with premiere CCE plugins the situation is similar
    maybe i wrong configuration of CCE or frameserver?? who is the good configuration
    thanks
