when adding chapter points why does it take so long for it to refresh the video????
i go to the spot where i want to add the chapter point, enter it in manually and then wait several minutes before i can do anything else with DVDit...
WTF!?!?!?!
I have a p4-1.7Ghz with 512MB ram and its only a 400MB video file.
Spruce DVD didn't have this issue.
whats wrong???
thanks
Originally Posted by staniks
go back to spruce mate - think i've tried nearly all low end packages. Don't give yourself a headache.
I've done all the fancy menus etc, and now i realise all you need is one menu saying "1 film 1, 2 film 2, 3 film 3" etc. You watch the films not the menus and chapters. -
i would but i don't like the fact that spruce makes everything a button!!
i want to add an image that does nothing. i got the layers down but users can still use the arrows to select the button even if it does nothing. it makes navigation a pain.
so how do i add an image (not background) without it becoming a selectable button? -
so how do i add an image (not background) without it becoming a selectable button?Jim
i had issues with dvdit pe and i got fed up and switched to ulead dvd movie factory nice menus, chapters and easy to use! dvdit did my chapters instantaneous though but it took forever as it transcoded all audio, i am happy with ulead
staniks
I would use a program such as Corel Draw. import graphic for background and import another graphic to be place on top or imposed on top of first. Save as .cdr file then export as a .jpeg file and then import the jpeg as the background for your menu with the graphic on a graphic already done.
JimJim
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
