  1. Umm, I feel like a real dumby for asking but could someone explain in better detail about this:
    http://www.vcdhelp.com/forum/userguides/100617.php
    [/quote]1. Scan the .avi for bad frames and correct a/v sync in VirtualDub first. If it is wrong to begin with, this method probably won't help.
    Okay, I get that you need to scan for bad frames and correct the audio/video sync first, but how do I know if I have "bad frames" and if I do how do I correct them? Also, the reason I'm looking for this is to fix audio/video that is in sync most of the time, but in tiny parts seems not quite right is that audio drifting? It says if it is wrong to begin w/, this method probably won't help. So what good is it if what you have isn't perfect and if you had something perfect then what do you need this method for? I'm confused!
  2. Ooops I quoted the wrong part, but hopefully you guys will know what I mean.
