  1. hehe ok i have a hauppauge win tv card and i capture using 352x480 for cvd's now i get lines in my picture and i can deinterlace afterwards with virtual dub but id rather not convert to avi while deinterlacing just to make a cvd afterwards.
    Is there a setting while capturing i can use so i can rid of these lines besides the deinterlace filter on the capture as this gives me frame loss.
    Thanks to anyones help in advance
  2. btw i'm capping from dish
  3. Capture to a lossless codec first then convert to divx, mpeg,mpeg2, etc.... The source is interlaced and those are interlace line you are seeing. Encoding after the capture will eliminate then.
  4. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Wht not just burn the interlaced mpeg. It will look fine on your TV.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  5. thats assuming he captured to Mpeg :P
  6. Member The village idiot's Avatar
    Apr 2002
    That would be an end product of mpeg2. And can be interlaced or not, but that is another topic.
  7. Is there a setting while capturing i can use so i can rid of these lines besides the deinterlace filter on the capture as this gives me frame loss.
    To summarize, no. And you don't want to.
    Anything you capture from an analog source with a vertical resolution over 240 is going to have those scanlines. It looks weird on your computer because your TV only reads every other line at any given moment. Like those before me have said, just burn it to your CVD. Those scanlines won't appear on your TV.
