What's up everyone. I'm new to this whole movie burning thing so I'll tell you what I got so far. I've got some movies on my computer that I've downloaded, but I want to put them on CD. Making them playable on dvd isn't really all that important, I just need it to be able to play off of my computer. The problem is that they are sucking up some massive space so I've decided to send them to a Cds. MOst of the movies are in Divx format, but they are ~716 MB per movie. Does anyone know a program that I can use that will shave ~16 MB off of my movies by either cutting the quality a bit, splitting the movie, or dropping it to a more compressed format (although I thought Divx was the most efficient out there)? I appreciate any advice that you guys have. Thanks.
Emrys
Sometimes converting them to MPEG-1 will compress them even further. And in MPEG-1 you can also vary the bit rate to shrink it even further.
Hello. -
divx is more efficient the mpeg1. You will likely end up with 2 discs or lose a lot of quality.
716 may just fit on a closed cd. Some may suggest overburn but that could cause future problems.
Another way is open up virtualdub and choose start and end point then do a direct stream copy both video and audio. Only the range you have chosen will be copied to the out file. Good way to cut excess off. Vdub only cuts on keyframe so it can be off a bit. Very fast way.
My last option, direct stream the video but compress the audio (full process). If no synch problem then you don't lose a thing. A bit slower than 2 but still pretty good cause you only process audio and video goes out as is.There's not much to do but then I can't do much anyway.
Advice for simple, free video-editing software for a newbie
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2011, 22:25 -
Canon Powershot SX230 HS HD video 1080p and 720p..pretty good for a compact
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2011, 00:24 -
BD Rebiulder Pretty Smart
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 27th Jan 2010, 16:07 -
Screenflow looks pretty good to me...anyone use it?
By Antoniola in forum MacReplies: 2Last Post: 22nd Sep 2008, 14:40 -
Any video player that plays pretty much everything?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2007, 19:12
