when i use claddvdxp it shows up with the 7.1 gig file. basically it has tons of vob files under it. but when i clad and rip it to a d2v, it only rips a file that is less than roughly 300 mb. what is the problem and how do i get all of that info out so i can encode it?
.d2v file size is correct. It's only a 'pointer" to the vob files so Tmpeg can see and encode as one file. you must keep the vob's on your HD for Tmpeg to encode.
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
Rip hard-coded subs from avi - VirtualDub filter and SubRip problems
By jujuandhuhu in forum SubtitleReplies: 4Last Post: 25th Oct 2008, 14:16 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28 -
TV Series Rip Problems (Eureka 7 DVD)
By Migs-se in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 03:36
