why can't I open my .DAT in wmp? I have tryed rename to .mpg doesnt work. I have nimo light installed.. what to do?
I have wmp 7.01 installed on win2000... I know the file works cus I tried opening it on another comp and it worked. wmp would play it on that computer.. is it some kind of codec I have to install?
It could be an mpeg2 and you are missing the codec.
Look on the left of this panel at other...tools...codecs... there is one there that says it is for use with wmp.
if you got this from P2P then its an incomplete download of a file.There's not much to do but then I can't do much anyway.
WMP 10 doesnt play mkv or mp4 files?
By jyeh74 in forum Newbie / General discussionsReplies: 13Last Post: 17th Nov 2009, 11:55 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
want wmp to open automatically
By chris_j11 in forum ComputerReplies: 2Last Post: 1st Aug 2008, 18:14 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 10:21
