I am using HI 8 to capture on Ulead movie factory. My goal is to burn to DVD-R with best sound and picture.
The following are the capture settings i used:
30 fps
720 x 480 resolution, UYVY (what does UYVY mean?)
48khz, 16 bit stereo sound
video capture filter (video properties)
Anyway I captured 60 seconds of video to AVI and it took up 555 megabytes of storage space. There is no way I can store 2 hours of video tape to my hard drive.
Why does it take up so much space? What am I doing wrong?
Clif Smith
AMD XP1900, 512ram, 100 gig drive. ATI All in wonder card, Pioneer DVR-103 DVD burner. -
I capture with Ulead Video Studio. When AVI capture is available, so are the codecs. Check the Comparisons chart at left to see which codec is right for you.
Hello. -
So.... do the codecs "compress" AVI files to make them smaller. Then you can convert that one to mpeg2.
I just don't have the hard disc space (60 gig free) to put a 2 hour video onto a dvd, at the rate of space that my current AVI capture is taking.Clif Smith
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 04:48 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
