I'm trying to merge two mepg1 files with the Merge & Cut feature of TMPEGenc.
The video of the two mpeg-1 files overlap by a few seconds. So, I need to set the outpoint on the first video to one frame or so before in the inpoint on the second video.
Makes sense, right?
But, for some reason, when I merge the two mpeg-1 files in this precise way, the merged version doesn't produce what I asked for. It gives me about a half-second of overlap!
I've re-done the merge a dozen times, delaying the inpoint of the second file ever so slightly each time. But, in the end, all I get is either a missing frame (which looks a bit weird) or a repeated frame (which looks even worse).
Any ideas on why this is happening?
P.S. I don't seem to be having the sync problems others have complained of -- just accuracy problems!!
MPEG-2 files are difficult to edit, because of there are three types of frame, I, P, B, of which only I frame is self-decodable. When doing cutting and merging, you must consider all the problems with these frames. That's why you can't do exactly what you want.
If you are a perfectionist and want what exactly what you want, you need to make every frame in overlapping area an I frame, I think. -
I do not believe the Merge & Cut function does it by frames. I do believe the Source Range function may give better results.
Hello. -
I just use the source feature in TMPGnc and encode cuts of a given AVI. Then I use Roxio's video maker and load all the cuts. It then merges them and burns. Has worked flawlessly for me and is simple.
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59
