Hi,
Quick question:-
AMD 1.2Ghz Athlon, 384mb ram, UDMA6 ATA133 HD.
Vid cap card = ATI Radeon 8500AV
VirtualDub ver.1.4.10
I can successfully capture at 720*576 @ 25fps and with filtering turned off get 50% Cpu usage and virtual no dropped frames in 90 mins of capture. I'm also using PicVideo MJPeg compression.
Turning on filtering and picking any from the list (or even having none loaded!) will render 97% to 98% cpu usage, mega amounts of frames dropped giving an output of roughly 3fps. I dropped the res down to 320*240 and it wasn't much better.
Results is I can't use filtering!
Any ideas?
Ian.
Home built:-
1.2GHz Athlon / 384mb ram / Full tower
AIW 8500DV
60gb & 120gb HD
Pioneer DVD- Writer, CDRW drives
Turtle Beach Santa Cruz soundcard -
Thats normal, Filters in Vdub are pretty much useless unless you are using them with already captured video. I even think the Vdub Readme mentions it's not recomended to try to capture with them on.
Hi,
Ahhhhh!, the penny drops..........THANKS!
Ian.Home built:-
AIW 8500DV
60gb & 120gb HD
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Should I use Virtualdub filtering options with a M2TS file ?
By rds11 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 16:50 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
