I bought a s-video cable to improve my resolution in captures from my handycam.
I set it up as the manual says, s-video from handycam to purple dongle and set the ati-tv to s-video .
I get Only black and white...?
I tried on the tv and it works great...?
Any suggestions ...?
I sent a problem report to ati...
Any one have this problem...
Robert
perhaps the color is messed up on either ur handy cam or the ati's color settings.
I have ATI TV wonder which came with purple dongle. Two months later I bought AIW Radeon which also came with purple dongle. One works for S-Video, the other only shows luminance signal - black and white - like you describe. Both purple dongles look exactly alike. I have swapped back and forth to verify problem. I conclude the one is defective. I haven't tried any continuity check. May not bother, I only need one working cable.
See if you can get ATI to send you a new cable.
For video card, should I get two Radeon 57xx or one 5850?
By jeanpave in forum ComputerReplies: 12Last Post: 24th Aug 2010, 02:17 -
no sound with radeon 5770 over hdmi
By lordhutt in forum ComputerReplies: 0Last Post: 20th Nov 2009, 16:14 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 16:08 -
Monitor Image Shrinks When Using Radeon 8500DV Video Outputs
By TwoTonCarmine in forum Capturing and VCRReplies: 3Last Post: 27th Jan 2008, 16:03 -
Ati AIW won't remember video resolution
By crimzind in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 17:07
