Hello,
I have home video (analog), which I have imported into iMovie. I'd like to make an SVCD using ffmpegX. I have been able to export .mov files from iMovie and make .mpg files using ffmpegX. But I've noticed that often it is suggested that the .mov files from iMovie should be imported into QuickTime Pro and exported with "high quality enabled" flag turned on. Is this going to make a noticeable difference given that my source data is probably only a 6 or 7 on a scale of 10 to start with?
Mike
I'm not sure how much it will improve quality, but you will need the Pro version of QT to be able to export movies. Pro and regular are the same versions, you just need a serial number to unlock the pro features.
You don't have to export the movie to enable high quality but you do have to have QT Pro.
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 08:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 16:06 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
