Hi All,
I have a couple of movies in AVI format which is about 750MB each, I want to convert these movies files to VCD so i can watch them on my portable DVD player. I have cut the movies in half (375MB) and tried using TMPGEnc to convert the AVI file, the out come is a 1,2gig file which i can not use to make a VCD. The other funny thing is, the mpeg file doesn't have audio when playing back using windows media player.
Any help would be appreciated. I really want to watch these movies while at school and work. Please help
1st of all don't cut the avi. Load AVI into virtual duband check for
junk frames. Then save audio as an uncompressed wav file.
Load into tmpgenc and follow the guide link below to
fit on 1 or 2 cd's.
(see section after DVD ripping)
http://www.vcdhelp.com/forum/userguides/84759.php
Don't forget that you will be loading the avi as your source
video (as normal) but also loading the .wav file as your audio,
not the avi as normal.
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 16:50 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
Hi All,
