Trying to backup Total Recall but Primo and Stomp wont let me. I guess cause of Copy Preotection. I tried the 'disc copy' method and Global Image method. Both say copying of this disc is not supported. So do i need different software to read and copy?
I also tried Decryptor and when i went to burn the iso file i found 2 Total Recall files. the iso file that was 3.9gigs and another that was 75kb. I know the 3.9gig file is the movie so just burn that one?
yes try the this tutorial http://www.vcdhelp.com/dvdripping and use the tool page to get some of the software
just my 2cents -
I got a vcdhelp.com guide that shows how to copy a 4.7gig DVD to DVD-R with Decrypter. After burning the DVD-R shows nothing on it. right click and properties shows no bytes but looks if it was burned to underneath.
what vesion of total recall are you taking about? i thought all versions of total recall were dual layer? if the region 2 is a dvd5 i would back it up.
Total keyframes?
By anonymous_whatever in forum Newbie / General discussionsReplies: 41Last Post: 12th Feb 2012, 11:33 -
Total running time
By mrcoolekin in forum Authoring (DVD)Replies: 26Last Post: 15th May 2009, 02:38 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 13:24 -
Does anyone on here use Total Video Player?
By weareone in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2008, 13:43 -
Total Newb-Help with video to TV
By jeff7602 in forum Newbie / General discussionsReplies: 4Last Post: 28th Feb 2008, 13:20
