Please Help. just started getting this error on Nero & VCD easy, When I try and burn a VCD/SVCD it comes up with the error "Power Calibration Failed" it doesn't happen all the time but it's getting very annoying! Can anyone suggest a solution? Thanks
AnonymousGuest
I've started getting this error too. every since I downloaded and installed the new VCDEasy_v1.1.4_Setup.exe
to those with the power calibration error problem. does the burning process stop or does it continue to the end.???
view the xml code my system ALWAYS reports power calibration not perfromed. but burns the cd anyway with good results. so I have just gotten used to ignoring it and moving on.
AnonymousGuest
I simply replaced my CD-RW .. and thats solved all my problems.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
Imgburn - Power Calibration Error message
By concisa in forum Authoring (DVD)Replies: 6Last Post: 12th Nov 2009, 15:39 -
Power Calibration Area Error
By zork152 in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Jul 2009, 17:27 -
Nero's "Power Calibration Error" fix.
By AlecWest in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2007, 19:26
