OK, I have a problem...I have Undisputed-SVCDrip and when using nero its like 1 minute too long for the 80 minute mark. I heard that there is a way to overburn the cd or something. Whenever I insert my cd and click burn it just says insert a new medium because there isn't enough space blah blah blah. Will Nero automatically overburn it or whatever? Or do I have to set something? OK well any help would be appreciated...
Also sorry if I posted this in the wrong forum this just seemed like the right one though.
Your Cd burner must support overburn. You might want to check around to make sure that yours will.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
