When care rippar a film, appears the following message in Smart Ripper.
"Somes files are locked!"
"Try to unlock with a player"
The movie is "Untitle", Surf Video.
Who to procede a unlocked
Hi - as the prompt says, all you need to do is run up, say, PowerDVD or WinDVD and play the disc for a few seconds - come out of that player and then run Smartripper again and all should be well.
Wc -
just to be safe, you shouldn't close winDVD or powerDVD after you played the DVD for a couple of secs....you should pause the DVD and then switch over to smartripper and try again
CAN ANYONE RECOMMEND A 'SMART RENDER' PROGRAM FOR .ts VIDEO FILES?
By QDM in forum EditingReplies: 1Last Post: 12th Jan 2012, 14:49 -
Locked MKV files, Multiple Instances of Explorer, PC Lag
By pushkin69 in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 22:22 -
Vegas smart render using mpeg2 ac3 files
By Ferdinand in forum EditingReplies: 6Last Post: 9th Nov 2008, 10:00 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
