does anyone know how to prevent the skew which comes with vbr mp3 sound when trying to open the avi file with vbr mp3 with virtualdub --- HOW TO PREVENT THE SKEW ??? - i know that there are virtualdub with vbr support and nandub but how to do it the right way ???![]()
Originally Posted by Tommyknocker
I'm having a similar problem... I can extract the audio and convert it to CBR MP3, but how to I re-combine it with the video?
p.s - thanks for your help, i'll try that -
If you intend to convert to another format, extract the audio as uncompressed wav. If you really do want to recombine the cbr mps with the video to produce a new avi then get hold of a copy of Nandub. This will allow you to interleave the mp3 and video (both direct stream copy). The option is generally used to create an avi with vbr audio, but will work just as well with cbr audio.
Bear in mind that to create a new avi with the same quality sound, the avi will be bigger!
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 25th Aug 2008, 23:59 -
Virtualdub and sound problem
By Shabaman in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 08:55 -
Virtualdub used with or without AviCutter=Sound Synch Problem
By johnharlin in forum EditingReplies: 11Last Post: 29th Dec 2007, 11:13
