Hey
I have a headache trying to work this prob out. I can capture video perfectly from my jvc camcorder to my pc but it is the sound that is the problem. It plays back in sync just very poor quality crackly and it sounds
very robotic etc. I am capture the sound at 41 400 at 8 bit mono in pcm format. I have tried various rates and various formats and compression rates with no joy.
I have a
Celeron 1.2ghz (P4 equivilant)
328 ram
40 gig hd
leadtek a170 video card
creative live sound card
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Silly Q but:
Are u sure you are using line-in and not the mic-in ?
Is everthing else but the line in deactivated in creative mixer?
Have you tried 44.1Hkz 16 bit stereo -> some people have
had problems capping audio outside that spec with creative
sound cards.
Have you adjusted the vfw (or wdm) settings for your
capture device to play wav without trebel or volume changes?
Perhaps if you posted what you capture with and all the settings
someone can provide specific answers. -
Everything in the creative mixer is deactivated. I have tried mucking around with the wdm drivers but not much I can change especially treble etc. the drivers are geneneric ( i think ie universal capture etc)
I am capturing from jvc camcorder using 352 x288 30 frames with sound at 44100 8 bit mono but have tried using various rates maybe the drivers are crap it sounds to me like it is a hardware conflict but everything in the device manger reports fine......
thanks for your reply it has helped greatly -
hahahah I worked it out
it seems there is a bug on my motherboard (using VIA Chipset) which cause distorted audio capture especially with sblive cards if anyone has these probs check out George Breese's patches....
Poor Audio: Effects Loud, Dialog too Soft
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 19:02 -
Audio quality very poor in 360p...but only on some vids. Help please!
By amb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Sep 2010, 14:06 -
Poor VHS or Poor VCR?
By ryangarfield in forum RestorationReplies: 10Last Post: 7th Jun 2010, 06:34 -
audio quality poor on ripped movie DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2009, 18:01 -
Copy DVD with ConvertXtoDVD and audio speech very poor.
By swog in forum DVD RippingReplies: 2Last Post: 24th Sep 2008, 16:12
