  1. Hello,
    I am trying to convert Panic room which is superbit with DVD2SVCD.
    I think the high bit transfer rate is causing problems. First burn created the whole movie on 1 disc with lots of errors. 2nd try wouldnt let me burn with fireburner at all.
    Do we have to change some setting for Superbit??
    I am realtively new to this, only keep my setting the way they are described in the how to burn with DVD2SVCD on VCD help, never tinker with them.
    Please advise on the workaround for this new format.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    the only differance is that they are higher bit rate 6000-7000 max about 8000
    they will require more compression to fit onto 2 cd's or use 3 or more for longer movies for svcd ..
    but since the source is better quality to begin with (most of the time - ive seen problems with some releases in some format conversions) you should have really good quality even if you want to really max compression ..
