Hi guys - I'm having a problem I'm wondering if you could help me with.
I've just started burning VCDs and I'm having a problem. I noticed all the VCDs I burn are too large for my TV screen.
I use virtualdub, tmpgenc and vcdeasy. I noticed this b/c some of the videos I'm burning have words on the bottom or sides and look fine on my comp. But once I pop the VCD into my DVD player I notice the words are cut off on the bottom and/or top. So obviously the files are too big.
Usually I don't mess with source and aspect ratios so maybe it's that. Can anybody tell me what I need to do to fix this? Its pretty annoying.
Well thanks a lot in advance guys. Take care
Results 1 to 1 of 1
Best solution for fixing .264 'added' black screen
By pilgrim365 in forum EditingReplies: 1Last Post: 19th Oct 2011, 21:21 -
creat dvd to fit your tv screen
By projecttemp in forum Video ConversionReplies: 2Last Post: 16th Jul 2008, 07:37 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 06:56 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 21:49 -
DVD fit on screen
By NHLroyrocks in forum Authoring (DVD)Replies: 6Last Post: 21st Jun 2007, 15:54
