I have a MPEG-1 (.m1v) file with a Constant Bitrate of 1000. It's an (X)VCD. Can you tell me what these settings are and if I should use them in bbMPEG when I multi-plex it the audio and the video together:
1. Reset clocks
2. Set broken link flag in GOP
3. Write sequence/program end codes
4. Use floating point
5. In program stream type, should I set it to VCD or MPEG-1 since it's (X)VCD?
6. VBR, should I select it?
7. Pad VCD audio
8. Write program end code
9. Align sequence headers
9. Pack options???
10. Buffer sizes (kB)???
11. Startup delay (ms)???
There are help files in bbMEG that explain it all. Just open the folder where the program resides and take a look.
Sony DVP-NC600 Multi-region question
By kc7gr in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Dec 2014, 23:44 -
request/ question ffmpegx and multi processors
By terramir in forum ffmpegX general discussionReplies: 0Last Post: 18th Dec 2011, 23:52 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 23rd Apr 2011, 00:59 -
DVD multi-region player question...
By mjl1297 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2010, 06:05 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 23:16
