Hi, I have encoded 2 different clips both 10 seconds long and contain the same music track. The first clip contains footage shot from a moving car. The second is comprised of a single still image (picture of a map). When I encoded the clips using tmpg with the proffesional VBR quality settings linked on this site I found that both clips were of the same physical size (MB) on my drive. Can someone please tell me why the clip made up of the still image is not smaller since there is no motion. Thanks,
Garyk
Maybe you do not have 0 (zero) as minimum bitrate.
"Enable padding" is maybe also on. -
I changed the minimum bitrate to 50 Kb/s, and that did the trick. Thanks for your help.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 17:53
