  1. If you rent a DVD that is a regular edition there is a chance
    that with some audio stripping the movie part
    will with on a DVDR with no transcoding.
    But with Superbit edition, I guess you could pretty much
    forget that will ever fit without re-encoding.
    But if you needed to transcode anyway, the higher the bitrate on
    the source the better the re-encode will turn out.
    http://www.superbitdvd.com
  2. Member vhelp's Avatar
    Mar 2001
    New York
    I've done a few. one example is my favorite, The Fifth Element.
    I have it on every type of media (well almost) VHS; DVD; SB.DVD**
    What I liked the most (IMO best quality) was: regular DVD. Go figure!!
    SB.DVD looks ok or great on TV and PC play via PDVD or WDVD but after
    a good transcode (RIP) it doesn't look as good a regular DVD. But,
    then again, I WAS using a lower than usual bitrate. So, that could'ov ben
    my problem, but then again, again, I've don'ess for quite of few DVD movies.
    And, I get the pretty much the same result. But, other than that, I'd say
    that the SB.DVD is of good quality, though on some, color is off or
    slightely on the lite side. Could be my eyes though.
    -vhelp
    ** SB.DVD - SuperBit DVD
