i dl 20% of an avi movie with the intentions of previewing it in virtual dub to make sure it is the correct movie, and then after i complete the dl, i convert it to mpeg. as i did so, i received this message that i have never recieved before with dl's. "error decompressing video frame 115, an unknown error occurred (may be corrupt data, error code 100. at that point it stopped the dub.
my question is: should i continue to dl the movie or would it just be a waste of time? does that error mean that i will not be able to convert it to mpeg or even view it as an avi? thanks
Sounds to me like a bad or corrupted frame. Go ahead and finish your download and run the file through Virtual Dub's Video-->Scan video stream for errors, then delete any bad frames. Save it under a new file name, and convert the new file.
Hello. -
ok, i did what you said. about 60 seconds into it i got this error message: "mmx state left on: T:\projects\virtual dub_old\videosource.cpp.1101".Originally Posted by Tommyknocker
any advice at this point? thanks -
about 60 seconds went by as i was scanning video stream for errors.Originally Posted by Tommyknocker
i just did a search and went to virtual dub and found that it is a misleading error that will be fixed in the next release of virtual dub. but, until then, what do i do at this point when it gives me this mmx error message and i click ok and it appears to have stopped doing its thing? do i save at this point and continue to convert to mpeg, or am i to assume that the file is corrupted enough to not be able to convert? thanks -
Guest
Try this on the avi you have 20% of:
First, get DivFix. After unzipping it make a COPY of the 20% file.
Start up DivFix and load the COPY of your file. Click on the "Strip Index"
then click on the "Rebuild Index".
This will give you a viewable avi that is only partially downloaded.
If the frame that you keep getting an error on is really screwed up you
may have to click on the "Scan for Errors" button first, then do the
other two buttons.
I have done this ever since I found DivFix about a year ago and it
always works for me. Even if I have errors in the stream, it would
rebuild the index as best as it could so I could see if what I had
so far was worth keeping.
Goodluck!
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56
