Objective: make a simple sequence VCD containing 2 MPEG-1 clips.
First Trial:
use Nero 5.5.9.14 default setting, drag & drop, then burn, smoothly. My DVD player recognize it as a VCD and play well(except skip forward/backward not working), but not play on PC(WinXP & MP8). It seems a common problem in this forum. Also notice the DAT file is about 10% _SMALLER_ than original MPG file. (I won't be surprised if DAT file is 10% bigger than MPG)
Second Trial:
use VCDGear make a bin/cue, then burn it with CDRWIN. The result DAT files are slight bigger than MPGs. PC can play the DAT file, but DVD player recognize it as a CDDA, even though it shows video with audio, and lost random seek functionality.
Third Trial:
use famous VideoPack5.1 make a simple VCD and burn. Similar result as second trial, plus random seek, skip forward/backward all working.
Commerial VCD:
play in both DVD player (recognized as VCD) and PC. Random seek, skip all function.
Compare with the commerial VCD:
All have 3 CDXA/mode2 tracks. While 1st track is about 16secs. By inspecting sectors of 1st track, the commerial also made by some version of VideoPack or WinOnCD.
The 3 authoring/burn tools I used all claim to comfirm "white book" spec in their manual. Why the results are different? How can I make a VCD like a commerical one?
Thanks advance for any comments.
Results 1 to 1 of 1
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39
