  1. How do you change where it gets the audio from? What I'm doing is recording from my GameCube, it gets the video fine, but the audio it's pulling of my webcam mike, which is a USB cam. I can hear the audio through the line-in on my sound card for the GameCube. That's what I want.
    Jul 2001
    germany
    hey, when you open virtual dub and chose "caprure avi" the options in the topic line change, there is also an audio button.. you can chose a format there...that's all i can tell you.
    I have the same problem with the audio, i can hear it through my line in but i can't capture it even though i tell my capture program to capture both audio and video, sorry guess I'm not much help here
  3. I had this same problem. even though your input may be set to line in (when you double click the speaker next to the clock and switch to recording properties), what you also need to check is the multimedia properties for windows. go to the control panel and pull that up. mine was set to microphone, once i switched it to my sound card (line in) it worked out great. hope this helps... marc
