Poll: Have you downloaded my CVD (NTSC) template?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 11 of 11
    Mar 2002
    United States of America
    Be sure to download my CVD (NTSC) template under the TMPGEnc Template section in the Tools menu.
    Mar 2002
    See poll question...
  3. d'loaded and looked at it. I'll give it a try......doesn't look bad at all.
    entirely TOO much time on my hands
    www.easydvdcopy.net
    Mar 2002
    Thanks easydvd!!! :P
  5. Are you familiar with any of the other template stuff I see around? Not just the KVCD stuff (which I mostly like - thanks Kwag!) but some of the ones that are in CCE2.64? Or any of the other templates I see around here and on Google? I hate making conversions that don't play on my standalone..........
    Know of anything good to suggest?
    www.easydvdcopy.net
    Mar 2002
    easydvd, I really don't know a thing about KVCD Templates.
    Sorry .
  7. take a look at them if you haven't. I think it's www.KVCD.com
    A couple of them have merit, although they may not play on a standalone. He also has a testing section for the ones that will along with mfr and model #
    www.easydvdcopy.net
  8. Originally Posted by easydvd
    Thanks easydvd,
    It's www.kvcd.net
    The .com was already taken
    -kwag
    KVCD.Net - Advanced Video Conversion
    http://www.kvcd.net
  9. oooooooppss
    www.easydvdcopy.net
  10. Member Conquest10's Avatar
    Chicago, IL
    how would you burn it? vcdeasy says its invalid and won't add the file. its great quality and i want it on a disk. can you help?
  11. somewhere in VCDEasy I unchecked the "make compliant VCD" box. I think you can do the same thing in Nero about "make compliant VCD" then just add your mpg from the template and go.
    www.easydvdcopy.net
