    Oct 2002
    Västerås - Sweden
    Hi
    I have a AVI (DivX) film that I want to convert to Svcd. I have split it and burned it as a Svcd, but the sound is late, the sound doesn't match the picture. When I'm about to split i using Vitruadub, I get a error message!
    It reads:
    Virtuadub has detected an improper VBR audio encoding in the source AVI-file and will rewrite the audio header with standard CBR values durin prosessing for better compatibility. This may introduve up to 9955ms of screw from the videostream. If this is unacceptable, decompress the *entire* audiostrem to an uncompressed WAV-file and recompress with a constant bitrate encoder (bitrate 147.4 +-19kbps)
    I have burned out the movie, but the sound falls behind...
    Which program can i use to fix it? How do I do it? I'm pretty new to the concept of vcd/svcd. So I need Fool-proof directions how to fix this..
    Please help me!!!
    Regards - Peter
    Ha de!
  2. Member Treebeard's Avatar
    Aug 2002
    Did you follow this guide to convert divx to svcd?
    http://www.vcdhelp.com/tmpgencsvcd.htm
    Did you do this to extract the audio file of the divx?
    http://www.vcdhelp.com/divxtovcd.htm#audio
