I was just reading a Divx (avi) to Svcd conversion guide and in it the guy states:
"In Windows Explorer, locate your DivX file, and RIGHT Click on it. From the windows that opens, go to Properties, then Summary. You will now see all the characteristics of the file. Write down the Frame Width and Height as we may need them later on and note the Data rate. If data rate is less than 100 kb/s, I would not suggest you continue. Also if the width is less than 480, I would also suggest you dont continue. The quality of these AVI's are poor and converting to a SVCD will only yield poor results. Convert these to VCD instead"
Is this good advice? Also, what would the rule of thumb for VCD be (data rate/width)?
if the AVI file, is bad in quality, then all other files you convert out of the divx will be bad, weather it is a VCD or an SVCD... (VCD will make it even worse)
I usually look at the resolution when i DLL a movie, movies with a resolution below 500*500i don't DLL *
* for other resolutions 500 * 500 = 250000 (other exemple: 689*478 = 32900 = goood)Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
no problem
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 18:15 -
DIVX to AVI conversion
By jjbodean1970 in forum Video ConversionReplies: 9Last Post: 18th Aug 2008, 00:05
