I have successfully burned a vcd and svcd and they both seem to work on my computer. The only thing is that they won't play in any dvd that I try them in. What am I doing wrong? I used the latest version of Nero to make them. Does PAL or NTSC play any significance when encoding the file? Also, does the type of cd-rw used make the difference, if so, which are recommended.
g2sat25
Its all dependant upon your standalone dvd player.
check the compatability section for your player.
some only support "pressed vcd's" (hollywood made) some players dont support cd-r discs . -
NTSC vs Pal is the first thing you should look at.
What is the TV standard in your country.There's not much to do but then I can't do much anyway.
DVD Burning causes Extremly slow playback
By PowerFalcon in forum DVD RippingReplies: 4Last Post: 27th Aug 2011, 15:47 -
DVD Burning on PC - Skips in Playback
By opieandy in forum Authoring (DVD)Replies: 23Last Post: 23rd Jun 2011, 16:35 -
Movies defragmenting before burning & playback artifacts
By zamar27 in forum Authoring (DVD)Replies: 4Last Post: 1st May 2011, 20:35 -
Burning AVCHD for playback in Bluray Player PLEASE HELP...GOING MAD!!
By nexus6634 in forum Authoring (Blu-ray)Replies: 4Last Post: 13th Feb 2009, 13:44 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19
