Hi there
I am using a DataVideo VDR-3000 to burn onto a standard CD-R in VCD format. I can play back the files on the recorder, but when I try and open them on my PC, it does not recognise the disc and treats it as blank. THe info on the DataVideo website (datavideo-tek.com) states that the discs should run automatically.
I have a P4 1.8GHz running Windows XP with a Toshiba DVD/CD-RW drive.
Hope someone can help!
Pete
UK -
hey there, i have similar problem. it seems that certain cd burner applications disables .dat files extension. i use HP software plus adaptec ez writer software. try uninstalling whatever cd burning software you are using. hope that helps...
Hi,
I am troubled by the same situation. Files created by VDR-3000 are not recognized by my software (Video de Luxe by Magix). As far as VCD is concerned, I solved this problem with the freeware "MPEGTool". With the help of this programm you can transform the character of a file from *.dat in *.mpg. After this procedures you shouldŽnt have any problems with handling your VDR-3000 created file.
I wasŽnt able to change the codec of SVCD files or cdDVD files created by the VDR-3000. TMPGEnc, for example, failed to recognize the SVCD or cdDVD format created by VDR-3000. Suggestions are appreciated very much. Best regards, Fritz
Microsoft- Please read!
By ahhaa in forum ComputerReplies: 9Last Post: 25th Feb 2009, 16:57 -
DV FAQ - Read me first
By Baldrick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Jan 2008, 17:40 -
LG DN788 not read VCD?
By joselect in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Nov 2007, 14:04 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
