Please point me to information regarding do it yourself conversion of VHS to DVD. What kind of capture card? Is that what allows you to record the VHS to the computer hardrive? If I buy a computer with a DVD-RW, will I need additional software? You simply play the tape from a VCR to the computer's hardrive and then burn a DVD from the hardrive?
<font size=-1>[ This Message was edited by: WiseMagic on 2001-08-20 15:22:25 ]</font>
See that cool menu over there on the left side of the screen? See the section marked "How To"? See the second topic labeled "Capture - VCR, TV, CAM, DV"?
I'd like to suggest that you read that..
Help with capturing VHS to make DVDs of home movies
By jrodefeld in forum Capturing and VCRReplies: 7Last Post: 1st Apr 2011, 00:09 -
Newb needs help with VHS home movies
By Subsoniq in forum Newbie / General discussionsReplies: 11Last Post: 4th Jun 2010, 17:06 -
VHS home movies to DVD and....?
By sdineen in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2009, 07:35 -
Simplest way to convert home VHS movies to DVD using VirtualDub?
By Pickngrin in forum Capturing and VCRReplies: 11Last Post: 21st Aug 2008, 08:32 -
Staticy/distorted audio exp'd when copyin some home-rec'd VHS movies to dvd
By corneileous in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2008, 17:33
