Made a XVCD mpg 480*480 with CCE.
but can't overburn to 800 megs with nero.
nero only allows me to burn 715 megs
p.s but if i make a compliant VCD nero allows me to burn 810 megs
can u please help!
buy a 800Mb cd... otherwise, it won't be possible...
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Dont listen to that guy above - I had this same problem, and was directed to and earlier forum. Nero has a problem recognising none standard files over a certain file size.
there are a couple options, Use another burning program, is one. But if you want menus, use VCDeasy to make yur menus and then turn it into Bin and cue files, then load your cue file into nero and burn it that way.
I have noticed while some files dont work - the CVDs that I have been making seem to work fine in Nero. im not sure why this is, but it is.Ok - you got me - i dont know anything - you happy now!
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57
