Hi!
I am trying to creat a photo cd which I can select the different tracks on it. The only problem is that these cds contain and upwards of 800+ pictures and I am unable to select the different tracks (each jpg is a track). The only way to select different tracks is by pressing the skip track buttons. This becomes a problem when I want to view pictures that have a high track number. It is very annoying pressing the skip track button 400 times!
I have burned a few photo cds using Nero 5.5 by dragging and dropping jpgs and played them using my Apex 660.
I know that I could make mpgs or the pictures and separate the mpgs by category and then burn them, but I want a process similar to Nero's.
Any help will be greatly appreciated. Thanks!![]()
Results 1 to 10 of 10
sorry. I dont have an answer but today I tried to do the same with about 1400 jpegs. my player is also an Apex and the highest # I could get to on it was 99. All the files burned but I couldn't get past 99. so don't feel bad bro. somewere on here is an answer for it.
Well I burned one with around 1800 images on it with Nero 5.5 and I am able to view the ones past track 99, but I just can't select the tracks I want to view because, I think, PBC only allows the viewing of sequintial tracks and no manual selection.
I read a post that said that creating a cd using WinOnCD would allow the selection of tracks, but I don't know where to get a demo of it. I also have VCD2tk but I don't know how to use it.
BTW Alucard, what burning program did you use? -
Hehe, thanks for the nfo alucard. I am now trying to make a cd using WinonCD 3.8 PE. I'm making one that is using the extended vcd option, and I will try using the photo album option next.
The only drawback that I have seen so far is the amount of pictures you can put on the disc. The maximum amount of pictures I am able to put on the xvcd is around 500 because it says the starting track has to be less than 66 minutes! When I tried making an album, I was able to put alot of pictures in each album, but since WinonCD seems to only like bmps, the pics take up alot more space. =/ I put around 1600 jpgs on the cd, and it said the disc run time ws 91 mins!
Is there a way to make WinonCD accept jpgs or am I stuck using bmps? Also, is there a way to make a photo album/xvcd with 1000+ pics on it using WinonCD 3.8 PE? As I said before, I have only been able to add around 500 because of the pictures taking up so much space when Win converts them to bmp, but the original pics are small jpgs taking up only 50-250kb each. Anyone know? Thanks!
[deleted -- I decided what I posted was probably incorrect when I though about it more]
<font size=-1>[ This Message was edited by: vitualis on 2001-08-31 21:40:27 ]</font>
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 09:26 -
Making a short audio track repeat in the video
By Xpenguin17 in forum AudioReplies: 9Last Post: 3rd May 2010, 08:01 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 09:41 -
Making new stereo from one track of existing stereo
By BobAchgill in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2009, 21:30 -
Nero 6 and Making a Photo CD
By solarblast in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2007, 11:56
