I'm about to upgrade my ageing Celeron 400 & m/board.
Can anyone comment on if this setup will be any good?
The Motherboard/CPU I am looking at is:
Gigabyte GA-7ZXR & AMD 850 T'Bird.
I currently have Matrox G400 Marvel with 2 Seagate Baracuda HDD's (UDMA66 7200rpm, 1 @ 20Gb (used for operating system - Win98 and file storage), other @ 30Gb partitioned for video capture & backups of other drive).
The 30Gig is partitioned as Primary 20Gb video only, ext partition 10Gb for backup.
Do the Gigabyte/AMD combo work well with the G400?
All my editing is currently either analogue from TV/Camcorder source, or DVD ripping to VCD.
I hope in a year or so to go DV.
Thanks for any constructive comments
Nezza
Yeah, that sounds ok. GA's have been known to be pretty stable and the dual BIOS comes in handy if you screw up a BIOS update.
However, the GA isn't an overclocking board (as I remember). If you pay a little more for an Abit, Asus, Iwill, etc (any board which overclocks WELL), you can increase your speed without paying more for your CPU.
Also, even if you DON'T overclock, get a good heatsink. Not that golden orb or OEM crap. Durons produce a lot of heat.
Suggested Capture Card
By Tucker19 in forum Video Streaming DownloadingReplies: 1Last Post: 12th Oct 2009, 16:06 -
Suggested video resolution to avoid overscan?
By andy_blah in forum Video ConversionReplies: 1Last Post: 14th Sep 2008, 04:13 -
Suggested DVD-Rs for Toshiba RDXS-34
By DJL82 in forum DVD & Blu-ray RecordersReplies: 27Last Post: 26th Oct 2007, 10:44 -
All-In-Wonder plus Theatrix (550 Pro) Suggested Drivers
By edDV in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2007, 01:42 -
Suggested program for compilation ???
By Kev90 in forum EditingReplies: 3Last Post: 17th Jul 2007, 01:08
