What is the difference among simple Stereo , Joint Stereo and Dual Channel Audio on a standalone DVD player whit 5.1 Speakers? Which of them are the best option for SVCD/CVD.
Thanks!
Good question. Ive been wondering this same thing for some time.
Anyone?
Article on Stereo VS. Joint Stereo
I havent read it but it may give you some answers
http://www.modatic.net/audio/stereo_vs_jointstereo.php -
Mid/Side Stereo a.k.a Joint Stereo - The encoder encodes to a mid channel, which is just one full channel by itself that is averaged out from the two original channels, and a side channel which contains all of the stereo separation. Instead of encoding two full channels like with normal stereo, the encoder only has to encode one channel and part of another. Sometimes there is too much stereo separation for JS to reproduce, if such a situation occurs, the encoder will switch back to normal stereo. This doesn't happen very often though, on most soundtracks, JS is used on about 95% of the frames.
Dual channel is for two different languages/dialects.
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 12:49 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 23:24 -
Stereo VS Joint Stereo
By Anakin in forum AudioReplies: 4Last Post: 26th Mar 2009, 14:22 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33 -
Why joint stereo instead of Stereo with alltoavi?
By regard in forum Video ConversionReplies: 5Last Post: 29th Jan 2008, 05:41
Thanks!
