I have a video that I shot and edited that was done with a NTSC camcorder. How do I convert this to PAL?
Can I just encode the avi with TMPGENC using a PAL template and then burn on disk?
Will this work? I have no way to test it to see if it works. I will be sending it to England.
Help! I'd like to be able to do this tonight if possible.
A lot of PAL DVD players here in Europe support NTSC, so check if that is the case with the player in England. If it doesn't then YES, you can just choose the PAL template in TMPGEnc and encode to PAL standard - it will work, however, it might have a bit jerky playback in DVD player if original was 23.976 fps and even more so if it was 29.970 fps because TMPGEnc does a lousy job at converting framerates. Best is to convert framerate BEFORE loading file into TMPGEnc. Here is the guide you need to follow to convert the framerate:
http://www.vcdhelp.com/forum/userguides/78178.php
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 16:48 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 12:46
