I now have a DVD writer and would like to capture to one file.I understand that Win98SE has a 4Gb file limit.Would Partition Magic allow me to have a NTFS partition on my second Capture hard drive while running Win98SE.I dont want to have to upgrade to Win2000 or XP if at all possible.![]()
No you can make a NTFS Partition with Partition Magic but win98SE won't bee able to read or write to it. So you have to upgrade to 2000 or XP.
Go for win XPChRaN :-) -
Steve4467,
Partition Magic will let you have an NTFS partition anywhere you want. Problem is, Win98 will not read from it nor write to it. There are special apps out there to let you read from NTFS, but last I checked, they wouldnt let you write to it.
If you want single files > 4GB you will have to upgrade to Win2000 or XP.
How do I get around the 5x change limit for DVD's
By trekker2u in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2011, 01:25 -
Question how to change TV card max file limit of 4.1 GB
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 25th Nov 2008, 08:47 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 10:02 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 05:24 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27
