I have tried to look for any useful information I might find in the forum but to no avail so I decided to go for my own problem posting here.
I have recently tried to use CCE SP 2.5 to encode the AVI files I captured thru Scenalyzer. At the beginning the error said I did not have a codec so I downloaded all available Codec including Canopus, Mainconcept, and some others for it. Then the error message went away, with another stepped in. This time I got an error of "ccd_encoding_init()failed : unknown error". I tried to convert my captured AVI filed by Canopus DV file converter to different, type 1 type 2 MS or anything together with the use of codec but it did not solve the problem.
I however was able to encode the same AVI file by TMPGEnc with a reasonable file size. BUT, the encoded MPEG file was not playable, in Media Player. Everytime I played it, a error always showed up 1 sec after and halted everything. After couple times, now it errored me just by clicking on the file ONCE(not need to play) in the windows explorer. The error said
<process has already exited> has generated errors and will be closed by windows.
You will need to restart the program.
An error log is being created.
After a minute the windows explorer shut itself.
I have tried several things this forum suggested, related or unrelated, but none of them seemed to work.
Can anybody help? This really drives me crazy.
Results 1 to 1 of 1
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 10:45 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 20:52 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 11:10 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 15:37 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
